- Oct 3, 2016
Good Day! One other culprit for this issue is Qustodio, the parental control software. This is a great multi-device approach to controlling and managing time and access on the internet for kids (if you are a parent, you must use something...and this is one of the best I have found...remember your kids can never "unsee" something nasty even if by accident).
Anyway, the PC client of Qustodio has a few issues in blocking access to things even on my administrator login account set to not be monitored or blocked. In one case it messed with Minecraft (until they fixed it with a patch, requiring uninstall/reinstall), another one was with the game "PvZ garden warfare 2" (could not connect to EA servers on any account on the PC).
Only recently, when I uninstalled Qustodio completely to get PvZ GW2 to work, did I find I could see my NAS in file explorer again (nothing else worked in this or any thread). I recently re-installed the client and noted my NAS was gone again!!! So I uninstalled again and re-booted and there was my NAS in the network file explorer as it should be. Test validated.
I have found "Qustodio" issues hard to detect/find when google searching on "a PC problem" so if you are reading this and use Qustodio, be sure to try an uninstall if you are finding something does not work with networking or access problems just to check that off the list of possible problems.
