Why hibernation option does not appear in ver 1803
Hello Everybody!
All I can see when I click on power button options is Block or Sleep
Is there any fix?
Tks. everybody
Do you have these options?
If so, that is all you get....
It might be good if you tell us more about your computer as in which version (home/pro) which build (current is 407) you have.
Since when do you have that issue?
Can you restore to the point where this did not happen??
Right click the Start icon and open a Command prompt (Admin)
Type Powercfg /hibernate on
Now, if you open settings - System and, on the left "Power and sleep", go down to additional power settings - Click on "Choose what the power buttons do"
You will now find you have the option available.
Later. I should add, if you dont want it anymore, just reverse the procedure. (Of in place of ON)
I believe there is a reg hack to enable it to be shown in the close down options.
I am using Gigabyte Mother, 4GB, AMD A10-5800K APU with Radeon HD Graphics, 3-80GHz. Windows 10 ver 1803 compilation 17134.407
Thanks a lot for everybody's time!!!!
Luis
Thanks!!!!davehc y finally understood how to turn hibernate on...I was doing it wrong!!!
Thanks everybody who helped, also
Best regardsLuis
