Powershell control speaker volume how?
Hi
I try to control my speaker volume with powershell. I found this script:
Function Set-Speaker($Volume){$wshShell = new-object -com wscript.shell;1..50 | % {$wshShell.SendKeys([char]174)};1..$Volume | % {$wshShell.SendKeys([char]175)}}
after
Set-Speaker -Volume 50
my speaker mutes. All -Volume values (10,20,30,40,50) doing the same only mutes my speaker.
Windows 10 Home latest. Any ideas how to make it works? How to change volume level?
THX
Maybe not the answer you are hoping for, but I left click the speaker icon on my taskbar and adjust it there.
I don't use Power shell much, so I confess your enquiry is a bit of a mystery to me.
I want to do it with powershell. I found this function that supposedly works and it doesn't work for me. So i hope someone can help me. Icon, taskbar....yes yes i have mouse to;) but i ask about this.
A quick look at the script, maybe you need to select a value in the 1...50, like “the 50” ?
