SOLVED PLEASE HELP! I have a strange running process (MidnightBlueByte).
Ok. Another. In the search bar type the full program name (programrabbittechnology.) and see if it will allow you to delete every instance.
But, you haven't exactly said it, have you tried merely deleting the whole folder?
As I wrote above I can't change anything from there..no option can be changed and I can't kill the process.
You can force stop that service with CMD method. Follow these steps:
1. Search for "Command Prompt" > Run as administrator.
2. Type sc queryex ProgramRabbitechnologiesBFO > Enter.
3. Identify the PID.
4. Type taskill /pid [pid number] /f > Enter.
For example you get 0811, then you must type taskill /pid 0811 /f
5. Exit and make sure the service is stopped, then uninstall the program.
It's impossible because the program still running.
I can see the owner is system - the plot thickens.
Run this reg utility, then right click the folder and "Take ownership" See if you can then get into it and delete anything
Fwiw. Have you ever download a backup program called rabbit-tech
  • Add Take Ownership to Context menu.reg
Bastet
Moderator.
Have you tried my suggestions to run MalwareBytes & AdwCleaner & if so what was the outcome?
Have you registered with the removal forum?
Have you tried uninstalling with Revo Uninstaller?
https://www.revouninstaller.com/products/revo-uninstaller-free/ If it refuses to uninstall then continue with the scan to remove any leftovers, this will force uninstall. If it still fails then you’re infected imo. A browser hijack may not affect other Windows programs. If the browser is constantly redirecting you to other websites then this is a good indication of a browser infection.
Edit: Found this: https://blog.malwarebytes.com/detections/adware-specialsearchoffer/ & https://forums.malwarebytes.com/topic/241332-removal-instructions-for-special-search-option/ which show you ARE infected by a browser hijacker.
.? Silence? Hope the op comes back with info. This thread is very interesting. I cannot find any reference to this “virus” on the web, other than postings on other forums by the same op
Ok so now I'm trying to kill the process in cmd and then delete. If not working then I'll try with Revo Uninstaller. I did scan with MalwareBytes but nothing found. I did not try in safe mode to scan tho but that is in queue TO-DO list.
Ok I wrote the first cmd.
Its saying WIN32_OWN_PROCESS and NOT_STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN.
Ok when I tried to delete its folder...(File in use) and it's back on task manager running.
What was the answer to my "Have you ever download a backup program called rabbit-tech"
OK. Tks for the feedback
I am still trying to trace the source! I see that BPO 's are often ransomeware. You haven't had anyt popups demanding money?
One of the notorious sites for getting this infection is an old Dos site - VETUSWARE.COM . Anything from there?
Bastet
Moderator.
When running Malwarebytes ensure scan for Rootkits is ticked.
No, I have no pops up just the process sitting there and doing nothing. This is my first time when I clicked on that site so no I don't think i got it from that Dos site. Is there any way to force delete the process from cmd or something ? Taskkill /f did work but the process gets back up. And how can I change the start-up from automatic to manual in service if the option is not clickable ?
