 - Nov 19, 2013
! Acronis does magical things!
Bob. Where is the "cop" currently? On your HD, or on media?
First, as you seem a little vague regarding its origin, make sure it is activated, or you might find yourself with unusable images.
It can be run direct from a HD installation, but it is better, and safer, to create a bootable media with the options in the Acronis menu.- USB or CD.
When you have done that, I would suggest to scan Acronis comprehensive pages on how to use it. It is relatively simple. But have a look here for starters:
https://kb.acronis.com/content/37574
Another word. After you have installed Acronis, if you look in the "Services", you will find three items for scheduled backups. These are not needed (unless that is your personal choice) and can both be disabled. When you try to make a backup, in the future, Acronis will complain that the schedule is not running, but, ay t the same time, will fix it for you. The three are also in the startup tab of the task manager, where you can also disable them.
