Hello,
hoping someone can help...I've built a new pc - AMD Ryzen 3600, 32gb corsair Vengeance pro ram, 1tb samsung 970 Evo plus NVme drive, 1tb samsung 860 EVO ssd, Powercolor 5700xt graphics card on a Asus Rog strix b450-i motherboard. Mentioning the above in case it helps.
I downloaded the windows installation iso and burned it onto a new usb drive. When I boot the system I can get into the bios no problem so it posts fine - no crashes. When I plug in the USB drive (btw I've tried two drives as well and installed the image by burning the iso and also directly using Microsofts media creation tool which creates the image directly onto the usb stick) the windows logo comes up and then a blue screen appears with the message 'Your PC ran into problems and needs to restart. we'll restart for you.' there is a variety of stop codes which appear below this 'CRITICAL_PROCESS_DIED' or 'IRQL_NOT_LESS_OR_EQUAL' and some others.
I've tried to change bios settings turning off fast boot, swapping boot drive options. Please help! Thanks in advance
