New Build 15063 later Per DS
I do see that. That wasn't quite the question. If I now turn off the Insider program on that machine will it then act and receice updates as a machine that has never been in the Insider program. Or is there perhaps something deep down that will, for example, stop it getting updates. After all Dave there are many cases on this forum of machines just not getting updates with no published reason...all those people and I know a couple who upgraded to Windows successfully from W7 and get updates to 10240 but for a hidden reason never received the Anni update even 6 months later. Maybe those machines will receive the Creators...or maybe not. It would be nice to see a list of the criteria from MS why some machines happily running W10 did not get Anni and if that means they wont get Creators.
Sorry Tim, that is a chance you will have to test out yourself. It Is, of course, an insider build. Why not just keep Win 10 running and wait three weeks for the genuine article. Updates through normal channels I doubt- There probably wont be any until the final release,
A cumulative update for 15063 has arrived. Just a couple of fixes.
This Cumulative Update brings the following fixes:
  • We fixed an issue where on Surface devices, Bluetooth radio fails to re-enumerate during hibernate/resume.
  • We fixed an issue with McAfee Enterprise to prevent a system crash when the product driver is installed on build 15060 configured with Device Guard.
As always, please keep sending in feedback via Feedback Hub.
Leaving the Insider Program (now) does not seem to be easy to do. Looking at your question I decided to try it.
First you get some options
My choice basically kicked me to the Reset page. I figured.... what the heck and went ahead with the reset, since I didn't have many programs or apps installed to lose.
Afterwards, I found my machine still on 15063 and ran Windows Update manually and got the Cumulative Update which bumped me to 15063.11
Hardly worth the hassle, and.....
I'm not absolutely sure that I was ever completely off the Insider Program.
After the reset completed and I was back to square one with all my Tiles and desktop icons set to defaults, I checked and while it was greyed out it showed some text that said something about
"Your machine is configured to receive Insider builds" and the box underneath had reverted from "Fast" to "Release Preview" and it was also greyed out.
Then after installing the Cumulative Update, which required a reboot, I went back and then it had a message "Fix Me" which referenced some changes that it need to apply to some security settings somewhere.
After which I got this
Clicked "Confirm" which again required a reboot and BOOM back to fast ring.
Big P.I.T.A. to end up back where I started, but.....
I thought I would give it a try anyway.
As I noted in the first image. Might be better to choose the other option and then wait for the actual release to come and go and see what happens.
As a side NOTE.... My production machine, which is not nor has it ever been an insider machine, that I manually upgraded to 15063.0 using the published official Msft ISO did get the same cumulative update and is now at 15063.11
Not sure if any of this helps to answer your question or not but it kept me entertained for a few hours.
WOW! I will leave the Insider machine as is until the official release appears. I think it did answer my question. When the 'real' edition appears I should be able to do an OOBE with that and be fully licenced. As I said, the machine WAS licenced and I have done nothing to change that I think.
Not being one who can leave well enough alone.....
I decided to try the other option to see what would happen....
"Keep giving me builds until the next Windows release"
Worked flawlessly, no muss.... no fuss.
One reboot and off the Insider Program.
Done.
Only problem... it already has the latest Cumulative Update so I'll have to wait for the next one to see if it has any problems updating.
I don't expect that there will be.
Done.
I am in the release preview ring. I will stay there until the 11th and then I am done, finis, kaput with the 3 ring circus.
Done.
I reread the whole thing and changed as you and Gideon did.
I reinstalled the Insider preview (the published Insider preview ISO 15063) on my test system with only a local account and not signed in to the Insider program. It worked just fine. No mentioning that it is an Insider Preview at all. Only thing I had to do was installing my storage driver (Windows update does not know about that one, the Vista driver works just fine)...
I even was able to update to 15063.11 . This shows me that this ISO is in fact the final (RTM) version of the creators update.... and one can get it two weeks early...... YYYAAAYYYY
Current build, for those who are going to move on!
10.0.16168.1000 (Redstone3)
How do I get this new build? I have tried Fast and Preview but nothing
No idea. I do not use the insider program, but I would think it will be coming there, on the fast ring, soon after the redstone 2 is officially released (Apr 20TH)
Fast ring build got this today
Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4016252)
Which bumped the build number to 15063.14
Interestingly, my production machine that I manually updated to the Creator's Update did not (at least not yet) and is still on 15063.11
I guess I'll see what happens on the 11th
Even my machine on the Release Preview ring got this one
Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4016251)
Which in turn, bumped that build to 15063.13
So something is going on. There's some speculation that on April 5th the Creator's Update will be available to everyone via the "Update Assistant" and the likely build at that time (day after tomorrow) will be 15063.14
That's all I got.... rumors and speculation for now.
https://aka.ms/ua1fkx
I got this one on my production machine today
Shortly afternoon 12:00 P.M. CST
I was beginning to get worried as to whether or not it would update normally, seeing as how it was a somewhat unconventional (early) install / upgrade.
Now to see what the 11th might bring, maybe KB4016252
They are all up now on the MSDn download and Visual studio downloads. (ISOs)
Evidently that has kicked in as well.
KB4016252 is already out. it increased the build# to 15063.14
I heard about that "early" release but have been unable to get it. Windows update does not know about it yet but I was able to use the Insider preview as regular install (no joining the program needed and it installed the CU's as well......
BTW: No member of MSDN here...... relying on the fast ring.... ;) :)
