- Jul 29, 2015
I totally understand what virtual memory is, and now it works.
What is the purpose of your link? It says nothing to support your claim. Note it clearly says, as you noted, the PF takes up "literally, about 1% - maybe even less" of the disk space.
If 1% matters, the disk is too full of other things.
The PF is NOT used for multi-tasking and no where in your link does it suggest it is.
The PF is used to cache data the system may soon need. SuperFetch is not a factor here either as that simply affects (on hard drives only - not SSDs) how files are arranged on your disk for faster loading. SuperFetch is NOT used to cache data or temporary storage. But in any case, that is part of that 1%.
Note the point of contention here is your claim the computer is slow is because the PF is too big. Again, if 1% matters, there are much bigger problems that need to be addressed.
