- Aug 18, 2016
Seems disabling the proxy server worked for me. Either under Lan setting or under Windows settings or directly through edge browser. Id check to make sure VPN is off too.
Okay.. so definitive resolution.
If the Windows Service "DNS Client" is turned off, disabled, or not running... Microsoft Edge will not resolve DNS entries.
I enabled and started the Service (It ended up being Disabled after the upgrade) and Microsoft Edge worked perfectly.
Enable the "Automatically detect settings" option in Internet Properties
If your computer is connected directly to the Internet or to a home network (and never connected to a network at work), you might want to configure your browser to automatically detect local area network (LAN) settings so that your computer can go online to obtain updates from Windows Update or Microsoft Update. To do this, follow these steps:
Windows 8.1 or Windows 8
Windows 7, Windows Vista or Windows XP
- Open Internet Properties.
Swipe in from the right edge of the screen, tap Search (or if you are using a mouse, point to the lower-right corner of the screen, and then click Search), type inetcpl.cpl in the search box, and then tap or click inetcpl.cpl.- In the Internet Properties dialog box, click the Connections tab, and then click LAN Settings.
- In Automatic configuration, select the Automatically detect settings check box, and then click OK.
Click Start, click Run, type inetcpl.cpl, and then click OK to open the Internet Properties dialog box.- In the Internet Properties dialog box, click the Connections tab, and then click LAN Settings.
From : https://support.microsoft.com/en-us/kb/818018
Ah.. actually disabling the "Automatically detect settings" fixes it. Not enabling.
Gracias
For me, anyway. Might be the other way for someone els I am not sure.
Click windows button, type dns, open proxy setting. And on edge go to advance settings and proxy settings.Where do you find DNS Client?
I am having the exact same issue. Microsoft Edge can't open or resolve ANY url's what-so-ever. However, all other browsers work just fine.
I can't make any sense of it. All other applications appear to have network and internet access without any issue. ONLY the EDGE Browser can't do anything.
Anyone got anything on this?
How do you enable and start the Service? Where do you find Windows Service "DNS Client"?
Thanks so much, Roland. Been going nuts here trying to get my www and http site completely secured with https, and everything was working great EXCEPT with Edge. When I followed your wonderful and very helpful advice, it started working great. Thanks again!OK, I found the following workaround. Not sure if this is the most elegant way, but it works on my machine and should do the trick until MS will release relevant fixes:
- Right-click the Windows start icon on the bottom left and select Network Connections
- Right-click the (wireless) adapter icon and select Properties
- Scroll down the list and click on Internet Protocol version (TCP/IPv4) and then click on Properties
- Change the DNS values from automatic to manual and enter the values Preferred DNS server 8.8.8.8 and Alternate DNS server 8.8.8.4 (Google DNS server address)
- Click OK
- Click OK
