DELL WLAN + Bluetooth driver is not installing
I seriously don't know how but this did the trick for me.
I was trying everything from uninstalling Drivers and running them in compatibility mode (tried win7 and win8 as well) but nothing seemed to work.´
Then I did as you said, uninstalled, unpacked my Drivers to a Folder, followed all the steps with updating Drivers manually (like in the Pictures) and then a message popped up that the Drivers are already up-to-date and the Installation was done. First I thought it would be another failure but then suddenly the WiFi was on and all the available Connections appeared.
Thanks a lot!
BTW: I am working on an ACER Aspire V3-571G (Qualcomm Atheros Wireless Network Adapter)
FIRST YOU DOWNLOAD WINDOWS 8.1 DRIVERS FOR YOUR SYSTEM
FOLLOWING THESE 10 STEPS
please like if it is work
Hello Gents,
I have a similar problem with my Dell Latitude D610. I can't see wireless icon anywhere even after pressing Fn+f2. I tried to install drivers downloaded from Dell website,but I am getting the same message like Activate bluetooth with wireless switch.Can anybody please show me a solution.
Thank you,
kamal.hossain@
Hi, Can Anyone help me I am not able to install WLAN, Radeon video, Bluetooth & some other drivers which are not compatible with windows 10... as previously I was using windows 7 which was running well... I am having Dell Studio xps 1640...
Hello All,
I have update my laptop to Windows 10 (64 bit) and now the system message pop ups on tart up : " Blietooth Hardware not found"
Please help with this.
#Dell Inspiron 15R 5110, 4GB RAM, Window 10 Home.
Does device manager show the existence of a Bluetooth device? Is it enabled ? Does it have the ! showing it is not working, possibly a missing driver.
yeah! I updated the bluetooth drivers from device manager. Working now! :)
Thanks!!
IT tech have 3 clients with same laptops running the 1705 wireless adapter and all drop or will not work added new netgear USB and all work. Dell drivers not working in 10 roll back to 7 /8 or get USB adapter.
I have a solution for wifi drivers in win 10(dell 3537)
follow these steps
1.first extract the windows 8.1 wifi driver 1705 in a new folder
2.then go to device manager and double click the wireless controller
3.then appear a new window<click drivers<click update drivers
4.then browse the extracted 1705 drive folder and click next
enjoy all
it's really works I made it after long time k
Bro I need solution to install the Bluetooth driver
Win 10 (15 3000) help me bro
Win 10 (15 3000) by mistake I have uninstalled the Bluetooth from device pls help
An 8-year-old post and no information about the computer in the current question makes it difficult to answer. I use Bluetooth mice on most of my Notebooks and the Bluetooth Wireless is part of the Wireless adapter on the computer. I get the drivers from the maker of the computers, usually uninstalling in Device Manager and rebooting will reload the driver/s.
