BSOD Stopcode: Driver Power State Error
That would tie in have had it permanently plugged in (Focus Scarlet 2i2 interface) for past 2 weeks. Nothing untoward showing in device managed so cant find where to uncheck as you describe. Have reinstalled Scarlett drivers.
Most devices associated with USB, including USB connected HIDs, Audio, Hubs, various dongles, etc., etc., will have a Power Management tab within that devices particular "Properties" dialog box.
Simply expand the group and individually, right click each one and choose properties.
IF it has a Power Management tab, check and see that the box is unchecked.
So if it works off USB or is USB (as in the various USB Hubs) examine its' properties and see what you find.
OK found the usb for the focusrite and unchecked the "Allow the computer to turn off this device to save power" . May need more than 2 days of crash free probs to see if it works.
AND.... so you know
Not only the device, but the port (hub) that it is plugged into.
That is why I suggested a more thorough examination of your various hardware components.
You're not going to cripple anything by unchecking that box, anywhere you find it.
You can always go back later and check it, if you decide that you want to.
