Windows System Repair - Repair not possible
Windows system repair reports
that repair is not possible and
In the file SrtTrail.txt the number of error causes = 1, but in all tests the error code = 0x0
in DISMRepairLogFile.txt
stands among other things
2024-03-26 15:32:54, Info CBS Failed to find a matching version for servicing stack: F:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.4163_none_7e304ec47c735f2e\ [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
This on Windows 10 Pro 22H2
because update KB5035845 reports error 0x80070057.
Thanks for a tip
Try running:
sfc /scannow
It should be run from an Administrator console (either a command prompt or Powershell prompt)
The error is reporting that the place that it uses to repair Windows "F:\Windows\WinSxS\" is different to what is actually running.
My understanding is that "WinSxS" is the Windows "Side by Side" file location.
Do you have windows in C:\Windows ?
This may also be the fact that Windows is not updating the location as well.
Unavailingly I ran sfc, dism and at last ccleaner.
At last I watched the update procedure with Process Monitor
and the last failure is NAME NOT FOUND by RegQueryValue
HKLM\System\CurrentControlSet\Control\WMI\Security\f27df866-c85a-518e-f34a-dc6fddbcd0c9
Could you please attach the log file CBS.log
It is located in:
c:\Windows\Logs\CBD
Thank You for viewing my CBS.log file
Because the zipped file was too big to attach, I linked it to
