- Aug 27, 2015
Ok I am Using a Steel Series V2 Headset.. plugged into the front Mic Audio in and out plugs.
The Volume is SO low it doesnt even pick up when setting up the microphone or using it on any VOIP Program
I already Re installed Realtek / Updated all Audio Drivers even used another Headset, Plugged into the back.. and used new Cables.
It worked just fine a week ago when I was using windows 7 ever since I upgraded to windows 10 My audio has not worked at all...
Then a Shit patch from Microsoft forced me to reinstall windows 10 which prevented me from reverting back to 7 Which I much rather do....
Already set The Front In as my Default recording Device, already messed with the settings to increase volume.. none of it has worked. This is EXTREMELY annoying.
