Will someone help me, please. Someone in my system.
I've had a problem since November 2020. I've wiped my Windows 10 system twice. It's not malware. It's a person on My computer. There are different apps installed that I didn't install. Most notably TechTools Pro. I can't open the app. The icon is grayed out in my Windows/Start menu. I can't remove the app. When I try to access the folders, it says I don't have permission. I need someone to remote into My system and look around. I've hired two techies, and they've both told me it's beyond their ability to deal with. I just disconnected my Windows Live account from My PC, which seems to have solved the issue. MAYBE?. There's at least a key logger on my system because they go thru and change the passwords on my accounts that don't offer 2-factor verification. I've even replaced the Comcast modem to ensure a new IP address. I need to figure out how they are getting into My system to stop it in the future.
Michael Bell
Mickey B
go could down load FREE version of Malwarebytes . Appears what ever it is , is running sopping you from shutting it down. I have my own bought anti virus AVG ultimate with Malwarebytes keeps my system running. I am not a big fan of MS antivirus.
Bastet
Moderator.
You say you wiped the PC, was this a clean install or just a reset?
Have you checked your router & other devices to ensure they’re not infected?
