The system does not act properly with the Optical mouse
I have 2 W10 computers and they started to act strangely with My Optical mouse via KVM ( and without KVM)
after click sometimes optical light blinks for a few seconds before the mouse responds to movement,
it started about 2 month ago
This is very annoying.
My Actions:
Check Windows events on mouse error.
Put mouse to diffrent USBs.
Reboot Computer with reinstall the mouse driver.
The system does not have any error
The problem says.
Any Ideas
Mest Regarads Moisey
My antivirus in BullGuard
System Info
Device name DELLW10
Processor Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz 3.60 GHz
Installed RAM 40.0 GB
Device ID 542541DB-8672-4551-A4F8-C911AA460C77
Product ID 00330-50593-10077-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Pro
Version 21H2
Installed on ‎4/‎16/‎2021
OS build 19044.1706
Experience Windows Feature Experience Pack 120.2212.4170.0
I also use a Wired mouse [no battery] connected to my KVM with 4 computers [different Operating Systems]. I haven't seen the issue but have you tried a different mouse?
Of the current types of mice I've not become comfortable with the TrackBall even though I was given one. I do have a Ball-type mouse that I use occasionally with an old Toshiba Notebook with MS-DOS 6.xx and Windows 3.1. The Wireless USB mouse that needs a dongle does need a battery as do the Bluetooth mice.
I got my first computer in '92 running MS-DOS 5 with Windows 3.1 as the GUI with a whopping 4MB RAM, 120MB HDD on an AMD 80386/40MHz. Everything had to have drivers for DOS. There were other versions of DOS, IBM-DOS, PC-DOS, etc. Windows 95 started merging the two. Back then there were mice with a center button [not wheel] mostly used with CAD/CAM programs.
