Snipping Tool - Misbehaving
I use the snipping tool multiple times a day if not hour.
Lately I have been having the following issue>
Left click upper left corner of image
Start to drag down and to the right
the snip stops on its own so I get 1/10 of what I want.
I thought, perhaps a mouse issue?
I also have Snagit installed and those captures work all the time.!
Snagit is a better tool but I find Snipping tool hand for its speed/
Ideas?
Thanks
Hi SpongeBob,
anything to do with your graphics card drivers?, what GPU do you have?. :)
IF you reboot your machine does the Snipping Tool work normally again?
Ideas?
Thanks
Go to 'Windows Accessories' > Snipping Tool > right click > 'Pin to start' then pin to taskbar, that is how I've got my 'Snipping Tool' as i also use it very often and this method has never ever failed and its worked for me perfectly without any problems.
Ideas?
Thanks
I've been having those problems too. I tried rebooting my computer, but I got the same problem. And the problem has also struck Snip & Sketch too.
Munkustrap. Welcome to the forum.
Good idea to look at the dates of previous posts before plunging in with a quick response like yours!
As davehc said. The issue with timeliness is that we've had at least 3 Version Upgrades since that post in Oct. 2018 and the poster's Version may be even older.
