Settings Not Working
Liv
I need help to get my Settings file to open, when I click on it nothing happens. I've tried the official troubleshooter but it says it hasn't found anything. I want to downgrade back to Windows 7 but I can't do that ( I don't think) without being able to get into setting.
Please HELP!!!
Hello Liv and welcome to the forum.
Right click the start button and choose "Run" from the context menu and in the Run dialog box type
ms-settings:windowsupdate
hit enter or click OK
IF that comes up, then select Recovery from the left column.
IF you have time remaining from the 30 day grace period you should be able to Roll Back from there.
Typeing Recovery Options in the search / Cortana box then pressing Enter will open to the page you need to be on if choosing a Rollback
