SOLVED Send to Onenote (Printer) lost from list of Printer Settings
I make great use of OFFICE 2013's Onenote to archive documents. I use 2013 'cos I bought it.
Today on trying to 'print' to it, nothing happened; usually a box appears asking where the doc is to be filed in Onenote.
I eventually discovered that there was no longer an entry for 'Send To Onenote' within Printers Settings.
I ran an 'Organise' of the Notebooks and when that failed to fix the problem, I tried a de/reinstall of Office2013 Pro but that did not fix it either.
I found a workaround using the Onenote app, but does anyone know why this might have happened?
OS is Win 10 64 - latest patches applied, as are all relevant Office 2013 patches.
Thanks,
Mike Duffy
Do you have the same issue with the other version, OneNote for Windows 10?
Havingre-installed MS Offrice pro as an attempt to fix issue (failed), a day later MS Update re-applied the missing Office patches and this fixed the issue.
