SOLVED Password reset
Click on your user name at the top right of the page. Click on Personal Details. Then on the left column of the page that pops up you will see Password. You can click on that and change your password there.
Thanks for reply. I had already been there, but current password is required in order to change password. I know from the dots that current password is 11 digits, but the choices I have made of 11 digits do not work. Is there any way to find out what current password is?
Try logging in with a different browser and use "Forgot password".
Windows 10 has Edge and Internet Explorer.
Ben
Or log out of the site in the current browser, close the browser then open and try to log in, should be a place for "forget password".
Kinda flakey, but managed to change password. I received 8 different authorization codes and kept trying them until one worked.
