- Oct 26, 2016
March 20, 2017—KB4015438 (OS Build 14393.969)
Improvements and fixes
This update includes quality improvements. No new operating system features are being introduced in this update. Key changes include:
If you installed earlier updates, only the new fixes contained in this package will be downloaded and installed on your device.
https://support.microsoft.com/en-us/help/4015438/windows-10-update-kb4015438
- Addressed a known issue with KB4013429 that caused Windows DVD Player (and 3rd party apps that use Microsoft MPEG-2 handling libraries) to crash.
- Addressed a known issue with KB4013429, that some customers using Windows Server 2016 and Windows 10 1607 Client with Switch Embedded Teaming (SET) enabled might experience a deadlock or when changing the physical adapter’s link speed property. This issue is most commonly seen as a DPC_WATCHDOG_VIOLATION or when verifier is enabled a VRF_STACKPTR_ERROR is seen in the Memory dump.
