SOLVED Home Page
go to settings=> view advaced settings => show the home button enable it => type adress => save
bingo :)
From your original post, perhaps you mean you wish to have your own home page, rather than the default?
Then, it is also in the settings
Just to elaborate on what davehc has already posted.........
Open Edge > top right, click the 3 dots > click Settings > under Open With, put a dot at "A specific page or pages" > click at the box underneath and select Custom > in the box under that > enter the url of the home page you want. I use www.google.ca as example > click the + sign on the right to save it > exit Edge.
That's it.
Reopen Edge and you will see the home page you want. In my example, it is Google.ca.
