- Sep 22, 2014
But you've yet to post it HERE!Went there, did that.
Something else is going on here.
I've never installed a driver for an IDE or SATA connected CD or DVD (Optical Drive).
Not in Windows 10, not in windows 7, not in windows vista, not in windows xp.
Does Device Manager show an optical drive?
Does the BIOS show the optical drive?
It's possible that the drive controller may have a physical issue or possibly may need its' own driver.
It's possible that the connection is bad on one end or the other between the device and the mother board.
It's possible that the connecting cable is bad.
As far as manufacturer support....
IF the machine is four years old or more.....
Good luck with that.
AND that goes for all manufacturers
Unless you purchased some super-duper warranty.
Maybe you need to update the DVD's firmware.
https://support.hp.com/us-en/driver...-1200-desktop-pc-series/5187025/model/5217188
Ben
HP SW820 DVD Writer Firmware Update 2.6 MB sp62027.exe will not install because I bought my machine in Sept 2012.
Try right-clicking the download and selecting "Troubleshoot compatibility".
Ben
Please mark as solved.
