Delete an extension in Edge
Hi, I installed an extension in Edge I'd now like to delete, but can't work out how. Thanks for any help.
if you hover over the extension you want to delete, you will see a settings icon in the right corner. click on it and it will give you the info about the extension as well as the option to uninstall it (down at the bottom), see picture as example:
No point really, in sending the op off to another link. Grizzly has covered the question 100%
