Wireless interface looses packages
Hi all,
I have a wireless pci card in my pc that looses packages. I have noticed that when my pc looses packages my wifes pc does not.
A simple ping google.com -t 100000 does the trick.
Since both pcs are in the range of 3 meters from the router and the signal quality is always top I wanted to confirm if the issues is coming from my pci card.
I have the feeling that my card is not very well pushed in the slot. Where I can find the hardware logs of the wifi cards in the windows 10 os?
Thanks
Alex
Hi Alex,
if you feel that the WiFi card isn't sitting right, shut down you PC and remove the power plug from the back of the PC and hold the power button in for several seconds, then take the PCI card out then put it back in again, it may be as you already stated that it isn't sitting in the slot correctly?. :)
I did this already.
But still where windows 10 keep log for hardware issues to have a look at my card?
You will find them here in Computer Management > Event Viewer:
10354
Or follow this path if you prefer:
%SystemRoot%\System32\Winevt\Logs\
