- Feb 18, 2021
I am having issues pertaining to both the sound device manager window and with the "App Volume and Device Preferences" window in settings (to change per-app audio device)
I am running a program that does not play back on the apparently assigned setting in the App Volume and Device Preferences.
Its set to the correct device whenever i open this window, however the program plays on the default playback device.
I have to set it to another random device and then back and works. but i have to repeat this every program launch.
The other issue im having is in the sound device manager and its to do with the "Listen to this device" box in the Properties menu for a Recording device. I have to do a similar to thing as with the other issue. in this case im using virtual cables and an EQ audio program ultimately listening to the output of the EQ on this device.
I have to uncheck the "Listen to device" and recheck the same box every time I am launching the app responsible for the base audio output.
Are there any possible solutions?
