I went to window community and posted this HELP msg and this was their response.
I am hoping someone here may be able to help me with this most frustrating issue.
i have spent literally 100s of hours on the internet and literally weeks searching into this and finding that other people are having the same issue posted at different sites but no solution.
Thanks for your time.
windows 10 system restore points not being created must do manual
Hello and Thank u for your attn:
Running win10
for the longest time my computer has not created an automatic restore point during installs. I have tried task sched to create system restore points and get no errors but no restore points are being created even tho history says task successful there is nothing in restore to show it created.
I updated win10 the other day to the most current hoping for a fix and i had a major problem after install all i got was blue screen after restart. Long story short, i finally got my computer back up and running, and it deleted EVERYTHING, all previous restore points and everything. But whatever i was horrified. I again enable system restore and again the same issues
no restore points created during new installs
no restore points created during scheduled tasks
Thankfully i CAN create manual restore but that is not the issue.
I moved the slider to max so restore has has much room as it needs
and dont give me the 7 days story for restore to create, cuz thats bs. regardless it should create as scheduled as it used to and it should create regardless during new installs and it simply does not. I know i am NOT the only one having this issue. In times past I can remember when windows would auto create restore points upon every install, and as scheduled regardless. I have no errors to report so i am at a loss
my hope of my update to most current win10 of August 17, 2016 would fix the issue as it was as if completely re-installing win10. It said prior to download that it was re-versable, which i found not to be true. It overwrote everything as if a new install, which i hoped would fix any issues. I was horrified that after the second restart all i saw was a blue screen for hours, and after i went on my phone to look here for help i found some solutions that finally got me back into my computer and all is running well, EXCEPT THE SYSTEM RESTORE , which was my cheif concern and problem. AND STILL IS.
thank you very much
ps
just fyi....i enabled system restore a long time ago, so thats not an issue
thank u
ps..thank u for the tips to get me back into my computer so i could get this far.
2 people had this question
Sachin Venkatesh replied on
I understand the inconvenience you are facing in Windows. We will help you.
Let's try the below methods and check if it helps to resolve the issue.
Method 1: Perform a clean boot and check if the issue persists.
to disable all non-Microsoft services consult the article called Clean Boot.
Follow: https://support.microsoft.com/en-us/kb/929135
Note: A clean boot is performed to start Windows by using a minimal set of drivers and startup programs. This helps eliminate software conflicts that occur when you install a program or an update or when you run a program in Windows. You may also troubleshoot or determine what conflict is causing the problem by performing a clean boot.
Disclaimer: After troubleshooting, refer to this section "How to reset the computer to start normally after clean boot troubleshooting"
Method 2: I also suggest you to perform a SFC scan (System file checker) scan.
How to use the System File Checker tool: http://support.microsoft.com/kb/929833
Keep us posted to help you better.
Thank you
Sachin.V
Microsoft Community
tnyshu replied
Hello and thank u for your response.
I did try all of your suggestions and i am at a total loss
system file checker shows: no errors
clean boot,
able to uninstall and install but no system restore point was created.
I have MINIMUAL things to startup anyway. but there are no conflicts whatsoever with the few that run.
Task scheduler history still tells me daily that a restore point was created successfully, yet it is not shown anywhere in the system restore dept. it only show my manually created points,
so it does not function as it did once upon a time.
and yet i have no direct errors telling me its malfunctioning or limted in someway
i will say this though as in my case
during the clean boot phase
simply typing in
msconfig
did nothing.
thankfully i saved the run command in the startup menu and did that
THEN AND ONLY THEN
did msconfig come up
So at this point everything is just as it was in my first post
Thank you
Running win10
thank you very much
ps
thank u
- Microsoft
- Support Engineer
Thank you
Sachin.V
Microsoft Community
tnyshu replied
clean boot,
simply typing in
msconfig
did nothing.
THEN AND ONLY THEN
Thank you
