Hi everyone,
I have a router with access to the internet. I connect to that router via wifi. I'm having trouble with connection speeds in windows 10 only. My system is a dual boot and the other OS works as expected so this is a windows 10 driver issue and not a hardware problem.
When I open the router up completely (no identification and/or encryption) I get expected results on speedtest.net (200Mbps). This is the same as I get in my other OS with the router secured.
However when I secure the router as per the config bellow I observer anything between 20Mbps and 70Mbps.
I would appreciate any help in identifying where the issue is.
The current router configuration is :
Mode : 802.11 n/ac
Channel selection: Auto (44)
Channel Bandwidth: 20/40/80 (auto)
Wireless Network: WiFi 5 GHz: Active
Supported Protocols: N,AC
Security: WPA2-PSK (AES)
My driver is :
Broadcom 802.11ac Network Adapter (version 7.35.118.68)
Thanks
Mode : 802.11 n/ac
My driver is :
Thanks
