Wifi password is wrong when it's not.
I updated my laptop from 8.1 when I got it last month. Generally when it's on my desk, I use an ethernet cable, however if I try to connect to our wifi it won't work.
The wifi network shows up and with a strong connection, but when I put the password in it says it's wrong. All other devices in the house that use wifi connect with no problem, I've even forgotten the network and reconnected with my phone just fine and my laptop connects to other wireless networks fine as well, it just seems to have an issue with my home wifi.
Thanks for any help ^^
What wifi security are you using? You should be using WPA-2 personal, AES+TKIP on both the router and the PC. Check that.
If your router is old and cannot do this then set the PC to whatever the router is using.
W10 Wifi can do all of the available security methods.
