- May 26, 2016
When ever I plug my wifi into the computer (usb, not into Ethernet socket or plug) the connection shows Ethernet and does not work.... as soon as I disconnect the wifi, goes back to normal wifi mode,,, I have disabled Ethernet numerous times,,, tried going into Network settings and changing the advanced banding that wifi is first on the priority list,, but after saving just goes back to Ethernet as the priority,,,, I had a problem with the connection some time ago and a "Professional" made changes to see if this worked,,, but causing lots of problems,,, all I want is to turn on,,, and if needed plug in to wifi,, NOT Ethernet... Please help
