- Oct 30, 2015
Hello everyone,
First post here and thanks for allowing me to be a part of the community!
My first question is while attempting to pin a website to the task bar in Edge I followed the directions and selected the "3 dots menu" and then selected "open with IE" option as instructed.
When I click on the webpage icon in the task bar the site indeed comes up but it is in Internet Explorer rather than Edge. Is there any way I can pin the site to the task bar and have it launch in Edge rather than IE? I understand it opens in IE because I opened the website in Edge and then told it to open with IE.
When I tried pinning the tab to the task bar in Edge I got the universal red circle with the line through it so I couldn't pin it unless I opened it in IE. Ive noticed when I pin a website to the Start Menu that it will open in Edge. Is it not possible to have a website pinned to the task bar and open in Edge?
Thanks so much for your help.
Appreciate interacting with you folks very much.
best,
rick
best,
rick
