What are the steps to convert MSG to PST using an MSG converter?
The simplest method to get rid of the hassle is by the use of the ToolsBaer MSG To PST Converter Tool, which allows you to convert all your MSG files to PST at once. You can take these easy steps to make the conversion happen.
1. Download and set up the MSG Converter on your PC or a computer.
2. Click on the tool and choose the option for multiple documents or folders.
3. Press the browse button to add multiple MSG files to the application.
4. Following that, click the button to examine all the mail messages and files in the MSG, including the attached files.
5. Choose what emails you want to save as a PST.
6. Specify the location where you wish to save the final PST file.
7. At last, click the "Convert" button to convert all your MSG emails to PST format, along with their attachments.
You can use the methods above to convert MSG to PST without facing any errors.
Shoviv MSG Converter Tool is a tool that helps you to converters the MSG files to PST files without messing with data and gives you expected results also provides couple of features that makes conversion process smoother and most important thing is demo version of the software to understand the tool’s users face and its capabilities.
Steps to convert MSG to PST using an MSG converter
Install and Launch the Tool
: First of all, download and install the Shoviv MSG Converter Tool and open it.
Load MSG Files: Click on the Add option to select the MSG files that you want to convert.
Choose PST as Output Format: After adding the MSG files, choose PST as the output format.
Select Destination: Choose storage location where you want to save the converted PST file on your computer.
Initiate Conversion: Click on the Convert button to begin the conversion process.
Finish: Once the process is complete, tap Finish and the PST file will be exported to the target folder.
There is an effective 4 step solution to convert MSG file to PST file using EmailsGuru MSG to PST Converter. It allow users to convert MSG file into PST format, protecting all data integrity and original folder hierarchy. This tool is designed or developed in such a way that both technical or non-technical users can efficiently convert MSG file to PST format. It is completely safe and easy way to convert or combine multiple MSG files into a PST file. It is fully compatible with all versions of Microsoft Outlook and Windows Operating Systems.
For trial version and get more details, visit here- Convert MSG to PST
