SOLVED Virus problem
trying to install hack for pubg mobile on pc i installed a virus autorun which desable windows defender as saw in the picture, how to reactive windows defender ?
That's what you get playing with public game cheats. They are almost always virus'. I would reinstall Windows. That's the only 100% way to get rid of one.
To add. If you are following such practises, it is even more important to have a clean image stored somewhere safe.
i just get attacked after that by a ransomeware who encrypted my files, windows defender can slove that if i can just turn it on
Ok. Good diagnosis. But, it was the virus which put that entry in the registry in the first instance. I would suggest you still do a search for a virus actually on the computer
