SOLVED USB 3 running at USB 2 speeds after upgrading to 15063.322
This may have only affected my specific Intel chipset but I just wanted to give you all an FYI.
The fix was to uninstall the XHCI extensible 3.0 controller and let it be rediscovered on reboot.
Check out the before and after results on my SanDisk Extreme USB 3.0 disk:
Hope nobody else encounters this issue but it is easy to fix.
Cheers,
WOT
I suppose you didn't look to see what driver version is was before & is after the uninstall?
Mine is 10.0.15063.296
4/27/2017
Renesas XHCI was updated, too.
4/27/2017
It was the same driver before and after: 10.0.15063.296. Thanks for asking.
