Good day to all!!
After updating from Windows 8.1 to Windows 10 I have the following:
Device Manager > Universal Serial Bus Controller : Unknown USB Device (Device Descripter Request Failed) which has a yellow mark.
I troubleshooted this and the details of the troubleshoot found this problem:
Location Port_#0002.Hub_#0003
Windows has stopped this device because it has reported problem (Code 43).
Now this tells me that I have a USB Device attached to my computer that Windows 10 was unable to find a driver for.
Therefore I did the following steps below without any success.
1. Within the Device Manager I uninstalled everything that was under the "Universal Serial Bus Controllers" to make sure when powered up back up everything (Drivers) would be reloaded/updated.
2. Shutdown power off.
3. Unplugged the power cord from laptop and removed the battery pack.
4. Unplugged all of your USB cords from the back of your machine as well as any flash drive or any other USB
device that is plugged.
5. Inserted the power plug back into the laptop and battery pack and power it up. Allowed it to completely load everything.
6. Started plugging the USB devices back into the laptop one at a time while waiting for them to
indicate that they are recognized.
7. Within Device Manager /USB Serial Controllers and checked to see if any of them have the yellow tag. The problem is not corrected.
Keep in mind that I did go searching for a newer Acer USB driver on the Acer site but nothing was available. Having said that, USB does stand for Universal Serial Bus - right? Hmm Need help.
Thanks in advance,
Steve
· The issue is when I connect my Acer cell phone (with a micro sd card). The above error shows up.
· This particular port was proven okay with a cable mouse - such as the other ports.
· Keep in mind that the cable and the device (Acer cell phone) was tried on another platform and worked.
Thanks in advance,
Steve
