I would ask exactly how to you print something, with a key combination or choosing print from a menu option on some utility?
If you check the printer in Devices does it show normally without any errors symbols? Are you using a Win 10 or HP driver for the system? Any chance there are two versions of a print driver running?
If it is wireless then you don't have the USB connected...?
Are there two "Properties" options on the right click menu for the printer? If you are changing settings, the Printer Properties is the admin version for such changes. There is also a troubleshooting option in that menu.
