The following method is to go to Safe Mode.
Let me know if you can follow the steps........................
Shut down your computer, then restart it.
at login screen, bottom right, click the Power icon >
left click at the Power icon will show you the Restart option >
press Shift key and hold > click Restart >
select Troubleshoot >
select Advanced Options >
select Startup Settings >
select Safe Mode >
select Safe Mode option, #4, 5 or 6. Does not matter which one.
If you can get to safe mode, do your system restore. Make sure you pick a date when you did not have that problem as your restore point.
