- Aug 8, 2018
Hi all,
I am experiencing problems with SSD's. Well, not really the SSD's but drivers.
I have a customer who is using Windows 10 2016 LTSB. He WILL NOT change this. When running, the SSD's lockup, freeze, whatever you like to call it, and the machine is unusable. Monitoring with task manager on the performance tab sees the active time eventually rise to 100% and then the machine freezes. Eventually Windows recognises the problem and attempts a re-boot. Of course what happens in BIOS is that Windows tries to boot from the SSD, can't and eventually just shows the BIOS screen. All my customers machines are doing this. (after some time, but they will eventually crash in this fashion).
The only way to clear this is to power cycle.
Using CHKDSK, I don't see any issues or errors.
However, if I use Windows 10 Pro, the latest version (bought last week) I do not see the lock up.
So the only reason I can work out here, is the SATA 3 SSD driver. I can't proove this because I can't download the driver from the Pro version and overwrite the LTSB version. The SSD manufacturer also does not have a driver.
Where can I get a Windows 10 Pro sata driver? How do I patch this in to Windows 2016 LTSB?
Kind regards
Jeff
Kind regards
Jeff
