SOLVED Slow going for PDF995
Need some advice. I use Pdf995 to print my 3D-Cad drawing. But it takes up to 10min for this pdf to get into my Designjet to print. :confused:
Hi Daniel,
do you have the printer driver installed as well?. :)
Thanks Wolfie.
Yes, I have. I get the impression the 3D is the problem. Maybe I need a faster PC. :confused:
Hi Daniel,
tell us what your specs are and we can advise you further. :)
Hi Daniel,
please mark the thread as solved if you are satisfied so it helps others. :)
