Settings problem
The settings window will not open when I click on the icon either in start-up, apps or "This PC" what's the problem is it an installation fault or something I'm not doing correctly? I can access device manager etc. and all the other Icons I've so far tried.
Robin.
What happens if you right click the start button, choose run and type
ms-settings:
and hit enter or click OK.
Does it launch or do you get an error?
ms-settings:
Sorry for the delay fell asleep in front of the telly! It tells me windows cannot find MS-Settings make sure you have typed the name correctly
it needs the colon after ms-settings:
Just to be redundant you can type
ms-settings:settings
