Screen Saver Not Functioning Properly. Help appreciated.
Hello, i recently was installing a screen saver on my computer and the download worked fine and everything, but it has yet to appear on my screen after waiting the specified amount of time. Here are my screen saver settings:
147872827312285
As you can see, the apply button is grayed out (I'm not sure if that's the problem?), and I've tried pressing OK as well. When I press OK, I waited about three minutes just to have nothing appear (as you can see, the setting is at one minute). All help is appreciated, thank you!
IF you have downloaded an installed a third party screen saver, can you revert back to a native Windows 10 Screen Saver and see if that functions properly?
Making sure that the times specified do not conflict with other power saving options like turning off the monitor or putting the computer to sleep.
