SOLVED Scarlett 2i2 Driver Problem
Tri
Hello i have this kind of warning in my driver
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Date: 7/3/2019 4:40:44 PM
Event ID: 442
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Computer: Tri
Description:
Device FocusriteUSB\Audio&Adapter\1&21e4188b&2&id:0000000012358202 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_0D8C&PID_013C&MI_00\6&2c96ffd3&0&0000
Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFFFFFFF122
Present: false
Status: 0xC0000719
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>442</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2019-07-03T09:40:44.587357500Z" />
<EventRecordID>2158</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="344" />
<Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
<Computer>Tri</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DeviceInstanceId">FocusriteUSB\Audio&amp;Adapter\1&amp;21e4188b&amp;2&amp;id:0000000012358202</Data>
<Data Name="LastDeviceInstanceId">USB\VID_0D8C&amp;PID_013C&amp;MI_00\6&amp;2c96ffd3&amp;0&amp;0000</Data>
<Data Name="ClassGuid">{4D36E96C-E325-11CE-BFC1-08002BE10318}</Data>
<Data Name="LocationPath">
</Data>
<Data Name="MigrationRank">0xf000fffffffff122</Data>
<Data Name="Present">false</Data>
<Data Name="Status">0xc0000719</Data>
</EventData>
</Event>
The problem is i have the sound interface scarlett 2i2 that detect sound in windows but doesn't bring any sound when i plug in the headset.
any solution?
Have you checked your sound settings to make sure the correct device is set to default?:
10344
Tri
Hello, i have checked my sound setting and the problem is solved, thanks for the answer.
The problem is security permission for user/group, i just need to click modify check box and that solved the scarlett problem. My interface is working good right now. The problem is solved.
