Restore using Reset PC gets "there was a problem resetting your PC"
I want to reset my PC to clear up some problems. I use the Recovery function for my version 20H2 Win 10. I select to "keep my files" and it stops and says "there was a problem resetting your PC". Now what should I do?
Hi roving,
you can follow the guide below but you will lose your apps!. You can install multiple apps by going to the following link. https://ninite.com/ :)
