Remove Edge & Mixed Reality Portal from Start Menu AppsList?
So has anyone come up with a way to remove the Edge and/or Mixed Reality Portal from the AppsList on the Start Menu?
I have seen a way to uninstall EDGE which may get rid of it in the AppsList too but I don't really want it gone, I just want more control over what should be My Appslist and where; I have a "Browsers" folder and I did put a working link to Edge there but I do not want it listed under the M's.
And since Creator's edition I have another app in the list I can't get rid of. I would like the Mixed Reality Portal completely gone. I did try forcing it to enabled so I could "Uninstall" from settings but even after that it still shows in AppsList.
NOTE: I 've also seen a way to completely hide the AppList but that's not what I want either. I actually use the list to start many of my programs and that's why I would like it grouped, showing what I want & how I use it.
You can uninstall them but they will come back on the next update.
Apps are located in the Windows folder instead of the Program Files folder.
