Recovery Drive from USB
It has been suggested that I should create a Recovery Drive from USB to enable me to reboot if I get problems.
However when I use "Recovery Drive" I get the following message "We cant create a Recovery Drive on this PC. Some files are missing. To Troubleshoot when your PC cant start use your Windows installation disc or media"
As I upgraded from Windows 8.1 I don't have a disc & what is media?
Hope you can help.
Couldn't agree more.
By creating installation media either on a USB device or a DVD, you are in effect, killing two birds with one stone.
You have the same features as you would have with a plain "Recovery Drive" but.....
You also have the means to actually perform a clean install or an in-place upgrade repair.
So...... you have the best of both worlds.
