I had the same issue once I upgraded from Win7 to Win10 home 64bit. The internet would randomly disconnect on my laptop. All other devices connected via wifi were fine, so I knew it wasn't the Router.
Here is the cause and hopeful resolution.
My Broadcom wireless N adapter is connected to the Router via wifi okay, but during the day the internet
will drop briefly and then the laptop locks up which then needs a full power off/on to fix the lock up.
I found that when I upgraded to Win10 Home edition 64bit earlier this year, that the Broadcom wireless N adapter driver was upgraded automatically with a signed driver by Microsoft :-(
I had to change the Broadcom wireless N adapter driver back to the original one that was installed when the OS was Win7 Home 64 bit.
Solution:
So you need to right click the start button and launch the command prompt as Admin.
Enter your Admin credentials ( hopefully you know this )
At the elevated command prompt As Admin type the following and then hit enter,
devmgmt.msc
Once the device manager window loads, navigate to Network Adapters and expand it.
Highlight your Broadcom Wireless N adapter, right mouse click and left click on properties.
Under the General tab make sure the device status is "This device is working properly".
Click the Driver tab at the top and check the driver provider details. Probably MS.
Click Update Driver
Click Browse my computer for driver software.
Click Let me pick from a list of device drivers on my computer
Now you should see a list of compatible hardware, hopefully it lists one or two Network adapters by
Broadcom.
For my laptop , I choose this one ( which was the original from Win7 64bit ) Your version may be different depending on the manufacturer of the computer and the Broadcom driver provided.
Broadcom Wireless LAN Driver ver 5.100.235.19
Highlight the relevant Network adapter, then click next.
That driver should be installed and you should see, that your wifi icon in your system tray will switch off and then
back on as it reconnects to your Router.
Once that's done you can close the window and see how that goes for surfing, hopefully it fixes your Internet issue random disconnects and unable to display a web page.
*** If it is still an issue, then you could try the steps above a choose the other Broadcom Wireless N adpater, or check the make/model of your computer and then check what the original wireless adapter driver version is via the manufacturers webpage. You could download it for Win7and then repeat the steps above and then where it says show compatible hardware click "Have disk" and browse to the folder where you downloaded the driver for your computer. Make sure the files are extracted first and then you pick the driver name which has a file extension of filename.inf and install that one.
Hi All,
I have a Packard Bell Easynote TK37 that has recently been "upgraded" to windows 10 and ever since keeps randomly losing internet connection. This is happening nearly every time I use the pc, it loses connection for 30seconds or so then reconnects.
The network adapter is Broadcom 802.11N
Connected to a Virgin superhub.
I have Avast internet security installed
Any suggestions welcome
Many thanks
