- Jan 28, 2016
so when I run novaroma.exe(program to download tvsieries) after double click I see from task manager that crash in 2sec. the curious is that when I install it run . but after first restart this problem appears.
windows 10 64b.
information 1
Fault bucket 128997008285, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: Novaroma.exe
P2: 0.9.9.2
P3: 567701dc
P4: Quartz
P5: 2.3.2.0
P6: 55197969
P7: 676
P8: 34
P9: GQ4LHWPDDL0MLXLXMR0BYB3HLMJR32NC
P10:
C:\Users\hwa_r\AppData\Local\Temp\WER9A80.tmp.WERInternalMetadata.xml
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Novaroma.exe_115a6645edf1155f2a7dde2916abfd43f5f66d7_54d5d128_09379f24
Analysis symbol:
Rechecking for solution: 0
Report Id: 7b66ccd9-bdcc-47b4-8a81-6d1513e695e9
Report Status: 0
Hashed bucket: 175f77227681f6f52eb71c16d0399a52
error 1
Faulting application name: Novaroma.exe, version: 0.9.9.2, time stamp: 0x567701dc
Faulting module name: KERNELBASE.dll, version: 10.0.10586.0, time stamp: 0x5632da1c
Exception code: 0xe0434352
Fault offset: 0x000bd8a8
Faulting process id: 0x740
Faulting application start time: 0x01d159ee1846e4a0
Faulting application path: C:\Users\hwa_r\AppData\Roaming\Novaroma\Novaroma.exe
Faulting module path: C:\WINDOWS\SYSTEM32\KERNELBASE.dll
Faulting package full name:
Faulting package-relative application ID:
error 2
Application: Novaroma.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: Quartz.SchedulerException
at Quartz.Impl.Triggers.SimpleTriggerImpl.Validate()
at Quartz.Core.QuartzScheduler.ScheduleJob(Quartz.IJobDetail, Quartz.ITrigger)
at Quartz.Impl.StdScheduler.ScheduleJob(Quartz.IJobDetail, Quartz.ITrigger)
at Novaroma.Engine.NovaromaEngine..ctor(Novaroma.Interface.IContextFactory, System.Collections.Generic.IEnumerable`1<Novaroma.Interface.INovaromaService>, Quartz.IScheduler, Novaroma.Interface.IExceptionHandler)
at DynamicClass.lambda_method(System.Runtime.CompilerServices.Closure, System.Object[])
at Autofac.Core.Activators.Reflection.ConstructorParameterBinding.Instantiate()
Exception Info: Autofac.Core.DependencyResolutionException
at Autofac.Core.Activators.Reflection.ReflectionActivator.ActivateInstance(Autofac.IComponentContext, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Resolving.InstanceLookup.Activate(System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Resolving.InstanceLookup.<Execute>b__0()
at Autofac.Core.Lifetime.LifetimeScope.GetOrCreateAndShare(System.Guid, System.Func`1<System.Object>)
at Autofac.Core.Resolving.InstanceLookup.Execute()
at Autofac.Core.Resolving.ResolveOperation.GetOrCreateInstance(Autofac.Core.ISharingLifetimeScope, Autofac.Core.IComponentRegistration, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Resolving.ResolveOperation.Execute(Autofac.Core.IComponentRegistration, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Lifetime.LifetimeScope.ResolveComponent(Autofac.Core.IComponentRegistration, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Container.ResolveComponent(Autofac.Core.IComponentRegistration, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.ResolutionExtensions.TryResolveService(Autofac.IComponentContext, Autofac.Core.Service, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>, System.Object ByRef)
at Autofac.ResolutionExtensions.ResolveService(Autofac.IComponentContext, Autofac.Core.Service, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.ResolutionExtensions.Resolve[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](Autofac.IComponentContext, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Novaroma.Win.App+<App_OnStartup>d__3.MoveNext()
at System.Runtime.CompilerServices.AsyncMethodBuilderCore+<>c.<ThrowAsync>b__6_0(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at Novaroma.Win.App.Main()
windows 10 64b.
information 1
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P1: Novaroma.exe
P2: 0.9.9.2
P3: 567701dc
P4: Quartz
P5: 2.3.2.0
P6: 55197969
P7: 676
P8: 34
P10:
Analysis symbol:
Report Status: 0
error 1
error 2
