- Apr 22, 2017
Hi all
the title says it all, I set up the PC to boot into safe mode using the "F8" no problem, the problem started after I ran a test safe boot using the F8 key, after I logged out after snooping around in safe mode, it booted automatically back into safe mode?.
I simply reversed what I did:
I simply removed the tick while in safe mode and rebooted.
The question I have is why didn't W10 boot normally after coming out of safe mode?.
Nothing like what is showing here was present btw?:
https://www.windows10forums.com/articles/enable-f8-safe-mode-boot-menu.8/
- Press the Windows + R keys simultaneously on the keyboard.
- In the available field of the opened Run command box, type MSCONFIG and press Enter.
- From the System Configuration box, go to the Boot tab.
- Under the Boot options section, check the Safe boot checkbox.
