Problem with power plans after upgrade from 7 to 10
Dear friends,
After upgrade from 7 to 10 my laptop keeps going in Sleep mode after 5 minutes. I tried to change power plans settings, but it didn't work. Also, I tried "change when to turn off the display>Change advanced power settings" but at the new window the button Restore plan defaults is not available.
I run at cmd powercfg -restoredefaultschemes ant took the message:
The power scheme, subgroup or setting specified does not exist.
I run also sfc /scannow and took the message:
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
I could give you the log file but is big! Perhaps you need a specific point of the file?
Could you help me please?
