Hi everybody.
I have a problem copying customized folders.
Before Windows 10 correctly copied customized folders from a disc to another or inside the same disc. Now, when I copy a customized folder, the customized look goes lost.
I make a practical example below.
1. Open Local Disc (C) and I create two folders. Let's call them "Folder 1" and "Folder 2"
2. I right click on "Folder 1".
A menu appears. On this menu, I select "Properties".
On "Properties", I select "Customize". Here I have the chance to change the look of my "Folder 1".
I choose a look of my choice ( any is ok ).
3. Now my "Folder 1" looks different from "Folder 2"
4. I COPY the "Folder 1".
I open the "Folder 2" and I PASTE my "Folder 1".
What do I get?
"Folder 1" without the previous customization. Why??? It is wrong. I'm copying something. It must be copied as it is.
5. I delete the copy.
I exit "Folder 2" and go back to Local Disc (C).
I left click click on "Folder 1" and, keeping clicked, I move it inside "Folder 2".
I open "Folder 2" and I find my "Folder 1" with its customized look. ( !!!! )
6. Now I open Local Disc (D).
So I have opened : "Folder 2" ( that contains my customized "Folder1" and Local Disc (D).
I left click on "Folder 1" and, keeping clicked, I move it in Local Disc (D).
ATTENTION : this time "Folder 1" will not be really "moved" from "Folder 2" to Local Disc (D), but copied.
Well, the result is bad again : the "Folder 1" is copied in Local Disc (D) without the customization.
So, it is rather clear that something is wrong when the folders are copied.
How to solve?
What do I get?
How to solve?
