I’m running a Dell M7710 with Windows 10 Pro. I have an external monitor (D2713H), a Wacom Cintiq, and several external drives connected. In the last several weeks, I’ve had a booting problem: If I disconnect all peripherals, the computer will boot in a reasonable time. However, if I do not disconnect all peripherals, Windows will bring up the Dell logo, but it will take a L-O-N-G time (>5 min, I’m not sure how long because I leave to get something else done) before the small circle of dots comes up and then the login screen.
In one of the Windows forums, someone suggested bringing-up Disk Management to make sure the external drives are not marked as Active. When I tried to access Disk Management it took 8 minutes to load the disk configuration information. Virtual Disk Manager then found an unknown Disk 2 that needs to be initialized. If I try to initialize it, I get a Device not Ready message, which makes sense because, as far as I can see, there is no device.
C: = Disk 0, D: = Disk 1; Disk 2 = unknown/not initialized; J: = Disk 3; E: = Disk 4; I: = Disk 5; K: = CD-ROM 0
Any advice as to how I might proceed?
